JustBeginning0124
- Messages
- 92
- Reaction score
- 24
I have a predator 224cc I’ve had it for over a year now, previously had it on a go kart and ran fine no problems except the idle. I just moved it over to a mini bike frame and for the first time am trying to figure out why it won’t go to idle. Seems the governor springs/control arm/etc is causing it as where it meets the carb on top it won’t close at all. These pictures are after I spent some time looking so yes right now the springs are “messed up” because I was trying different ways to fix the problem. But even installed the correct way the problem is still there. Sorry if I worded this horribly lol I’m sure it’s butchered. First picture is how it’s looked since I don’t know when honestly since I’ve had I’m sure, the second one is what it is supposed to be. It’s almost like the governor arm is not pulling the throttle lever closed so it can sit at idle. It is also not staying running when the choke is off. Will only run on closed choke and obviously does not run with nearly as much power as it should. Any suggestions??
