Razor Dune Buggy upgrade
marcleman
I've had a Razor Dune Buggy for about 10 years now and it's still holding up well, but now I feel like I want some more speed on it. I've done research on a lot of forums but I don't really know where to start. I mainly want a high top speed (20-30mph) with some big wheels on it.
I've been looking at the Electric Scooter Parts website and I've seen a kit on there that might look good, but if there are better things out there then I'm open to buying those.
Would this kit get me the speed and power I'm looking for? I'm not very informed with electric motors and batteries.
EpsilonZero
...still cheaper than a boat!
It all depends on what you want to do with it. What do you consider overkill? Keep in mind it comes stock with #25 chain, so it can only take so much power until you have to swap out for something stronger. The axle is some proprietary metric size that you can't get off the shelf components for, so I suggest you just swap it out immediately.
I've done quite a bit to my son's dune buggy. I realized that I set up the spindle and axle diameter to the same 5/8" and 1" as my kart and I don't get enough grip any more so I am handing my wheels and slicks down.
EpsilonZero
I finally beefed up the front end by welding up some new spindles and running tie rods individually to each wheel. Now the toe can be set without the steering ending up crooked. It also has proper Ackerman now.
New spindles, pre-threading:
Almost complete... I had to wait for some flange bushings to press in.
20240520_212521.jpg Previous steering tie rod bold vs new bolt, installed.
Test ride:
Donald.J.Trump
Donald.J.Trump
I found this as peddlers mall 24 bucks.. tested it, runs off power , battery not charging... this is gonna be fun... gadsmotors with shift look enticing
