Sequoia Electrathon Racer
Now put some thin pieces of wood on the sides to make a comfortable hand grip.
Hey Denny,
I like that idea :thumbsup:
So, I found a piece of oak, left over from a project from ~20 years ago ;)
...& cut a 1" strip off of it
Rounded the edge, with a router
...then, did the other side
...& then, some fittin' & trimmin
Next step was some sandin' (smoothin' & roundin')
...then, applied some stain (also from ~20 years ago) :cheers2:
Love the color
...&/so, here is a close up view :sifone:
You been cutting off of that tv back for a while now. How big was that thing? Looks good!
Hey Denny,
I used up that (1st) one years ago
...but, I come across them every now & then & pick 'em up
Here is my last acquisition :thumbsup:
I think it will look great! 20 year old stuff looks just as good as new stuff. It will be more comfortable in your hands too.
Yup, I agree :cheers2:
Also, added some Satin clear (ta seal 'em up) :2guns:
...after preppin' 'em for the connectin' hardware :cool:
While the clear, on the hand grips, was dryin', I did some cleanin' on the steerin' wheel (left handle, so far)
...usin' an ultra fine Scotch-Brite pad & some WD-40 :thumbsup:
...& then, some polishin'
After lettin' the clear dry overnight, I started putin' 'er together :cheers2:
Hand grips installed, on the clean-n-shinny "wheel" :sifone:
How’s she feel? Did you hold it in your hands and make race car noises? Oh, wait, I mean whirring noises.
Feels good :thumbsup:
Of course :sifone:
Oh yea!, I even "worked" the imaginary clutch while I "went thru" the imaginary gears :banana:
But
Once installed, I noticed a bit of a clearance issue with the A-pillars
Grippin' the wheel
top(er) view
side(er) view
So, Ima thinkin' that Ima have ta, probably add a little more bend, to the steerin' wheel
...ta bring them hand grips inwards & away from them pillars a bit more ;)
Lets make a rear fender outta some black (TV back) plastic ;)
Formed the sides with a heat gun, over a couple of 2 x 4's
Added a "bulge"
Turned out kinda like this (so far)
Another view
Next, let's work on a battery box ;)
Measured the battery module
...& drew out a plan
Transferred the plan to steel
Worked on cutting 'er out
Here is the cut out (blank) rounded & smoothed
Then, put 'er in the bender
...& did some bendin'
Turned out kinda like this :thumbsup:
...& the back side
Here is the (16S) 60V 15AH Lithium battery module (removing old enclosure)
Now, let's work on a terminal cover (more TV back material) ;)
S for Sequoia :sifone:
Bent using a heat gun & some wood "forms" (& an industrial paper weight) :lolgoku:
Battery module "in the box"
...ready for the wiring (& stuff) :thumbsup:
I found that Ima outta XT90 connectors
...so, I had ta order some (more)
Tap...tap...tap...
Um...while we wait...I guess we can paint some stuff
So, I removed the rotor
...did some smoothin'
...& some cleanin'
* This triple flange hub is a "work of art" :sifone: (Thanks T) ;)
...& then, some paintin'
