adapting 3/4 " to 1" shaft
hobbykart
I need to adapt a 1" bore clutch to a 3/4" engine shaft , does anybody know of a source to get one ?
frederic
The Junk Man
New Jersey
If you're worried about durability you can take anderkart's idea (which is a good one BTW) and weld the bar stock in place then machine around it to return it to it's original shape so the clutch slips right on.
frederic
The Junk Man
New Jersey
No, he said he had a 1" bore clutch and a 3/4" shaft, which means the shaft is too small for the clutch's bore.
If it were the other way around, one just has to machine the output shaft of the engine to the smaller diameter.
This way, one needs to effectively enlarge the shaft or replace the bore with a smaller one. Using a collar is an effective way of doing this, as long as it doesn't "slip" because if it wiggles even a little, the outer edges of the keyslot on the engine shaft and the inner edges of the keyslot on the clutch will start to round over time, and that will allow the key to wiggle even more. This continues until something breaks or tears, as the wiggling will wear down the key itself so that it's narrower in the middle.
welding it together and machining off the excess is one way of preventing the wiggling. Another is to pin things together, i.e. a hardened pin or bolt through the clutch's bore flange, the collar, and the engine's output shaft.
freakboy
the names 'mater
hick town
yeah and quick question should it take a long time to grind welds with a angle grinder? with a grinding disk i have cut off wheels for it but im not sure if i should use them the manual says only use ones with the indent like thing not flat ones.
freakboy
the names 'mater
hick town
alright its just taking for ever cause i need to get down in a corner and the wheel is kinda rounded on the end
Hey great idea's frederic, that extra tall key wobbling back and forth would definitely be the weak point of this mod.
Welding the bushing to the inside of the clutch hub itself might be another option to consider so the key could be easly replaced if necessary and the PTO would remain completly un-modded. This should give good support for the key and also allow a quick easy installation of a 3/4" replacement clutch at some point down the road.
