Can I swap springs on a stock cam?
Yea.
You can go with 22# springs and 1.3:1 stamped steel rockers.
It'll make the cam feel bigger, and give you around .288" lift.
You got plenty of break in time on it, I say, start tuning it,
I got .002"- .0025" piston to deck on this 1, so a .027" thick gasket will be perfect, make sure you measure the gasket. I checked a 3 shim 68mm and it was only .021", it should have been .027".
On the head, dont open the intake runner, it's too big as is, jus rough it up, and work the area around the valve guide, lay those steep drop offs down into nice slopes.
The exhaust won't take much work, its bigger then any 212 exhaust port. Jus take off the sharp edges, and smooth the rough areas.
Take those sharp gasket edges off the intake and exhaust, and gasket match those.
Smooth out the rough spots in the chamber, and take off the sharp edges.
Anytime you take a head off, go ahead and lap the valves to the seats, these lil engines have the worst valve seats.
I've probably see 5 or more that was leaking this year.
The jetting, head gasket change, head work, those 1.3:1 stamped steel rockers, and 22# springs, I'd bet that 12t sprocket will work for you then.
Here's the 1.3:1 stamped steel rockers. You might find a kit with springs.
I've broke these rockers with 26# springs, but 22# springs are no problem.
NON Hemi Heads and Clone Heads ONLY will not work with a Hemi Head. Predator NON HEMI Clone KART RACING ROCKER ARM 1.3:1 RATIO GAIN 30% Lift! THESE WILL NOT NOT work with the Hemi head engines! 30% more lift with ANY CAM!
www.ebay.com
