I may tease you but I still want to see you succeed and build the best machine possible.
Hey Denny,
Yup, I know
...& think of you as a friend &/or collogue
I think upon brake application you will end up with a hard pull on one side. The upper cable is going to be pulled further out than the lower one. But if you flipped the whole thing horizontally it would pull them both evenly. Check out the math and geometry for yourself, don’t take my word for it.
Well, in situations like this I try-n-look at things from different perspectives (or in different ways)
So, "if" a guy was holding on to (2) ropes
...& had (1) in each hand
...he could pull on either rope, as hard as he wants, individually
But, "if" those (2) ropes were connected to, lets say a board with a hole in the middle of it
...& had a broomstick ran thru the hole
...& then, the guy was holding on to the broom stick, on each side of the board (with the (2) ropes attached to it)
Could he pull on either rope, harder than the other one?
Whether he was holding it (the broom stick & board) Vertically or Horizontally?
* The dual brake cable connector, would be "the board"
...the bolt, would be "the broom stick"
...& the pedal, would be "the guy"
