Which axle kit do i get to convert a manco critterto a live axle setup?
Sandmanbjj
I just got one from go power sports. I measured my old axel and matched the length and diameter.
I probably didn't need the entire kit but I also have a 1 wheel peel kart I may convert to live axel. Now I will have the parts to do it.
I imagine you will need to weld on some brackets to hold the axel. So may need a welding machine added to your parts list.
shady113
Port lavaca texas
I have a welding machine and all the tools. From end to end it's 39" the 1wp axle is bent. Can I put a longer one on? Or does it gotta be the same length. It's 5/8" diameter. So the one from bmi parts, is it a good quality axle kit?
shady113
Port lavaca texas
you can use any length you choose. but keep in mind how you want to haul it.....what looks good....the addition of wider tires......balance and reasonableness.
Da redflash
So would a 44" be to big? And there isn't too much ti choose from when it comes to sprocket placement... so am I going to have to move the mounting plate for the motor?
