Flygirl
Hello all, just purchased a used kart for a singular purpose.
Bear with me now. I have an 18 degree grass yard that I need to mow. No riding lawn mower will work.
I use to race go karts many years ago and thought the low gravity of a go kart would stick to the hill towing a push mower behind.
I know weird.
So I plan on building a kart that will go a cross a lawn and then climb to go the other direction.
So looking for info on gear ratios and how to install a jackshaft to get the torque I need. Also size of engine to make all this happen.
All info welcome
G.W
Nyssa Oregon
Post some pictures of the kart and we'll go from there. If your using it purely for utility put a predator 212 on it.
GW not enough information for a recommendation yet on engine size. Relax buddy.
Flygirl if we could get a picture of the yard (hill) approx weight of kart, tire size and type, lawnmower type (pull behind ATV type). We could help you out with more information. Start a thread! We love this type of stuff! And :welcome2:!
Flygirl
Really appreciate the help.
Will supply requested info soon.
You guys are great!
  • Like
Reactions: G.W
ExTrojan101
Fort Myers Florida
Hello Ladies and Gents!
Just purchased 2 coleman197 karts and looking to get them lifted a bit higher and really want to add bigger tires which seems dam near impossible! Me and my so are also going to swap the stock engine for a Preditor ghost.
G.W
Nyssa Oregon
Can write get some pictures?
Hello and welcome! Start yourself a thread, you'll get a whole lot more replies. And pictures there, too.
pearl111
Baltimore, Maryland
I know weird.
All info welcome
Welcome to DIY, sounds interesting.
Bansil
Painter of gnomes....
I know weird.
All info welcome
That's not weird at all, you can add two cheap mowers side by side with hinges, and then a 3rd behind so the all float. You can do 48 inches with cheap mowers.
Google diy Tow behind mowers.
Only downside I see is learning to mow and not tear up yard with a live axle, wide corners etc.
This should be a fun project.
