How should I mount this clutch? 🤔
Vertrees
Does it have to fully be on the shaft
redflash
if you just stand a little to the right...........they look lined up perfectly......Thats how we do things here 1
Da redflash
Vertrees
Make sure the bolts are long enought to have atleast 1-/2 times the diameter engaged
Ie:1/4-20 needs to be screwed in 3/8 of an inch engaged
1/2-13 would need atleast 3/4 of an inch enga
Da redflash
I like the way you think… I’ll follow those steps
Atlanta, GA
Is the brake rubbing against the engine case? If some of those nuts were removed could you move the brake over and slide the engine to align the sprockets?
Vertrees
Da redflash
No but it’s mm’s away from touching
