Mikart 710
- Messages
- 4
- Reaction score
- 8
Thankfully I can weld and fabricate. I knew going into this project it was going to be pricey but the experience for my daughter will be worth it.It's going to be expensive....
I bought a single seat Murray with full suspension and it has been very expensive.
As far as steering and brakes there is no bolt on upgrading. You will have to learn to weld and modify the parts.
For steering you can get a rack and pinion off Amazon that is for a go kart, but you will need to make mounts for all of the parts and possibly lengthen or shorten your tie rods.
For the brakes you should get hydraulic disc brakes. You might be able to get some on the front, but probably not without lots of fabrication
I appreciate the parts breakdown. I plan on upping the engine size a bit so I wanted to increase braking strength and steering reliability. I feel the cage and chassis are fairly well built however the steering is mediocre at best.I wouldn't get too involved with upgrades. The steering on these karts is poorly designed. Check for any worn bushings or tie rod ends, check for seized A-arm pivots, make sure the tire pressure is correct.
As far as the brakes, take the caliper off and apart. Clean the adjustment pin and bolt to make sure they're free. Reassemble then run the adjustment bolt up until there's slight drag on the rotor. Tighten the locknut.
Here's a 710 manual.
Mine is definitely aged from the Arizona sun but everything came apart relatively easy.Every suspension bit on my kart was seized. I had to pound and cut out bolts, and cut out 3 of the 4 shocks. Do keep in mind that my kart came off the coast so the salt and moisture got to it before I did
Lucky, mine was aged from salt and rust, there was no such thing as "moving parts"Mine is definitely aged from the Arizona sun but everything came apart relatively easy.
