continued affordable mods
BrownStainRacing
Way too lean on both low and high side of rpm range.
Not enough ignition timing.
over heating the combustion chamber and upper end of the cylinder sleeve.
Keep rpm under 4800 rpm. it's not gonna fix your problems, but it'll let your piston and rings live a lil longer, till you get the carb and timing tuned in.
You will have a different plug reading with the colder ngk bp9es plug.
Your air box is good. You should have plenty of air moving thur that filter at 4800 rpm.
student👍
plainfield
Woah, how did you do that?
how'd u tell that it didn't have enough timing? and the cylinder sleeve?
but especially the timing,
also how bad do I need that spark plug?
BrownStainRacing
That's years and years of playing with that ol junky sbc., hei distributors, and holley carbs😆 🤣 😂 😹
I find with a colder plug, I can dial in on the tune faster. A couple jet changes, timing changes, test passes and it's there. Again, that years of reading plugs
I like that plug for testing then I switch to the autolite 3910x. It's also a cold plug, jus really hard to read.
  • Love
Reactions: G.W
BrownStainRacing
ok then knowledge it is
is there a mechanic's bible I should know bout?
or just any book or thing to read that teaches bout mechanics
Keep your eyes and ears out for a "mini bike engine swap" in your area. those guys will practically give away the small 163cc-196cc engines.
Those are excellent platforms to learn how to build, check specs, set clearances on.
A properly set up, speced 196 will embarrass a you-tube built stage this, stage that crap, 212. They'll be loading that junk back on the trailer, 😆 🤣 😆 🤣 😂 😹 😆
I wouldn't be picking on the 223,224, 225 guys. Or you'll be the one loading back on the trailer, 😆 🤣 😂 😹
  • Like
Reactions: G.W
