I need to know what transmission to use, and where to find one cheap.
gusbin80
VA/WVA State line
So, I have a little all terrain go kart project that I'm working on right now and i need to find out what transmission to use for it. I'd prefer not to use a CVT/Torque Converter and I'd much rather have an actual shift-able transmission.
Specs:
45hp 725cc twin barrel carb swappped supercharged Kohler courage 26(?) v twin
currently mounted output shaft down but I'm planning on longitudinally mounting it very soon
I'm also very broke so any cheap suggestions are greatly appreciated.
Will send pics when I get a chance to
Specs:
:welcome2:
Did you modify the oil system so it can be mounted longitudinal? With 45hp unfortunately nothing will be cheap. I don’t have suggestions but someone here might.
The Jeffco is the only thing that I know will hold up. They ain’t cheap! If you could get a Harley trans for a modern trike conversion with reverse that could work too I guess. What supercharger did you use? How does it run? Got any pictures?
mrblanche
Morgan, TX
There were "real transmission" on early garden tractors, and some of those were really stout. Forty-five HP is, however, also very stout, and gearing would be a problem. Just doing some thinking out loud, here.
redflash
Did you say cheap ? maybe you better find a different hobby. The only cheap things about go Karts is what you weld, fabricate, invent, or
make...everything you can buy.......will not be cheap !
Da redflash
