I’ve heard with big Arizona cams on Predators, that you gotta clearance the crankshaft.
I have never seen 1 that worn without figuring out something went wrong early. That's crazy. I'd say it started during the break in period.Actually I do have the cam still. You can’t even see the exhaust lobe in the first pic and the second shows the little lift left
Yeah everybody likes 'em cuz them are cheap. I got mine on sale for $100!No idea. The engine came on the kart I bought and this all happened before I ever even opened it up. Probably a reason why they were selling it.
I ended up just buying a whole new engine to have a fresh start and force myself to learn about it with taking it apart and installing all new stage 2 stuff. Thank god predators aren’t crazy expensive
Very good idea.No idea. The engine came on the kart I bought and this all happened before I ever even opened it up. Probably a reason why they were selling it.
Hey Ltdan, did you get a Hemi or a flattop? I got a Hemi, we can learn together from @BrownStainRacing, the 'turd' motor expert.No idea. The engine came on the kart I bought and this all happened before I ever even opened it up. Probably a reason why they were selling it.
Dynocam 265I have never seen 1 that worn without figuring out something went wrong early. That's crazy. I'd say it started during the break in period.
I hope you checked the push rods, rockers and replaced the lifters.
What cam did you go with???
I went with a non-Hemi since the old engine had a non-Hemi PVL Flywheel.Hey Ltdan, did you get a Hemi or a flattop? I got a Hemi, we can learn together from @BrownStainRacing, the 'turd' motor expert.
I finally took out the new engine yesterday for the first time and I’m addicted to the exhaust rumble! Topped out at 39 MPH, which was so freaking fun and rewarding for the countless hours I’ve put in the garage. On the other hand, I think a 39 MPH top speed is low compared to what I’ve seen on YouTube for Stage 2, even with my 220lb ***. Plus, that means my engine is only running at 5600 RPM with calculating the 5:1 ratio, 11.5” tires, and reverse engineering the 39mph, which also seems low for stage 2.
I hate that I had to do it, but I took the engine off the kart this morning to check clearances like turd McGee recommended, since I know it should be reaching higher speeds. Pray for me gentlemen.
I have a ARC +.020 Rod, but how the heck do you vent the crankcase?At that rpm, I surely hope you are running a billet rod and are venting the crankcase correctly. If not, that stock rod will vent the crankcase for you.
I've seen more stock rod preds with busted blocks then I have clone 196cc with stock rods. Idk what it is about the pred stock rod, it jus can't handle high rpm. Even the "Box Stock" racers won't turn em passed 5300 rpm.
Very nice!!!!!!I have a ARC +.020 Rod, but how the heck do you vent the crankcase?
Head gasket is +.010. I still have the vent tube coming from the valve cover. Since I took the vm22 from the old engine and put it on the new one, I took the new OEM air filter, cut a little piece out, and stuck that in the end of the valve breather. Did the same with the gas tank breather too. I will def buy a 1 way valve on eBay. Thank you!Very nice!!!!!!
I use 1 way check valves. That stock valve/baffle in the valve cover , can't keep up with the pressure at higher rpm (4k +) so it hangs open and draws in more air when the piston is going back to the top of the cylinder. This causes really high pressures under the piston, slowing the rpm down, engine jus can not rev any higher.
If you don't have any 1 way check valves yet, DO NOT REMOVE THE STOCK VALVE IN THE VALVE COVER, it will cause more pressure.
Check ebay or Amazon for 1 way check valves. I like to use the 1/2" ones. If you can't find em I'll lokkem up for you.
How thick is your head gasket you are using???
