After I cleaned up the go kart from our mud bath yesterday I noticed the rear wheels were really close to the swing arm. I looked and the collars that the hold the wheels out had slid inboard.
The axle kit I bought is a single thickness all the way. So it uses collars to keep the wheels from sliding in board. The collars use two set screws to keep them in place. I previously tightened those set screws down REALLY tight. I was concerned about messing up the Allen head set screws. So what do I do to keep the collars in place?
I thought about staking the set screws in place, but they go below the face of the collars. Buy longer set screws and then stake them with a chisel?
I thought about lock tight the set screws, but I really haven't had good experience with lock tight, maybe I'm using it wrong...
I thought about putting the collar in place, tighten one set screw down. Remove the other set screw and drilling a dimple into the axle for the set screw to sit in. Then, doing the same process for the other set screw. But, I'm worried about the drill bit messing up the threads in the collar. I would use a drill bit quite a bit smaller than the hole. But, I'm worried about the drill bit wandering due to trying to drill into a round axle.
What's the best way to keep the collars in place?
