Ok, cool it is a thirty series.
Thanks for checking it out, much appreciatedOk, cool it is a thirty series.
They didn’t have any color, just a metal coloring really. Maybe it wore off? I will say that this kart has a lot of low end power, it takes very little acceleration to take off quicklythe driver clutch may not have the correct stock springs. the previous owner may have fooled with the stock springs in the driver to achieve activation at a lower rpm, thinking he could get more speed by lowering the bottom end. what color are the springs in the drive clutch, usually the color will rell you the rpm range they are set for. My guess ???????
Da Redflash
I just read an article describing how to choose and adjust the springs like you recommended, that’s definitely my next move. These go karts are sneaky little things, always slipping their hands in my pocketif you look at the go power, omb, and other websites, many have a graph that tells you exactly what rpms the clutch will grab with a specific spring set. you can vary the take off point from 1200 rpm in increments up to 2500 or more. check those out, they're cheap so order a few different sets
so you can fine tune the rpm that activates the torque converter. if your idle is around 800 rpm....I would get the springs for 1000 or 1100 rpm. then you can start your motor....stand there and look at it.....then sit down without it running over your leg
Da redflash
