Hub with internal drum brake and sprocket
evan22
Hello all I am new here and bought my son a kart for Christmas that I am fixing up . The drive wheel is a 6 inch hub with a 60 tooth sprocket with a drum attached. The rim is cracked on the bead and need a new one . Can I still use the sprocket and drum or do I need a whole new assembly ? Please help
Can't see why not, BUT the teeth on the sprocket look like they have a lot of use. Like worn out. Get a new sprocket and chain to go with it.
evan22
Does the sprocket separate from the rim ? When I removed the hub bolts the drum and sprocket are solid on one half of the rim .
evan22
Any suggestions on an easy kit to replace that drive wheel ?
Howdy & :welcome2:
I'm not sure on all of "your specific" details
...like, what size axle your kart has (maybe 3/4"?)
So "Just food for thought"
...but, maybe something like these:
Rim
https://www.bmikarts.com/6-Aluminum-Wheel-4-wide-34-ID-Bearing_p_3276.html
Sprocket/Brake drum
https://www.bmikarts.com/Sprocket-60T-for-35-Chain-with-4-Brake-Drum_p_10940.html
Be sure to double check "the details" before purchasing, like
...axle size
...brake drum size
...tooth count etc.
* Brakes?
I see it has a brake pedal
...but, couldn't see the rest of the system
evan22
Howdy & :welcome2:
Rim
Sprocket/Brake drum
...axle size
...brake drum size
...tooth count etc.
* Brakes?
Thanks . I found out it's a Azusa tri star wheel with and they sell the sprocket drum combo also
You don't need to pay the high price for parts carrying the Azusa name, and using their 3-bolt split rims. Just use cheaper aftermarket parts, and I personally prefer 4-bolt split rims. I see you have a combo split rim with 3-bolt internal combo drum brake drum and sprocket. At least it looks internal (machined internal for the expanding brake shoes inside), as opposed to external (machined external for a band brake on the outside).
60 Tooth 35 Chain Sprocket 4-1/2" Drum Riveted Mini-Hub 1" Bore Machined OD - OMBWarehouse.com
AZ2267-ID - 4-1/2" Drums with Riveted Hubs 60 Tooth Sprocket - Machined ID | Go Kart & Mini Bike Parts | MFG Supply
evan22
Thanks ! I got a 60 tooth sprocket on Amazon for 43$ was way cheaper than Azusa site and quicker to get . Just want to have it put together for Christmas. Getting it powder coated it got sand blasted today
mohangj
I may be late to reply,
In India we weld and machine the hub if it is expensive or not easily available. They run decent after the weld.
redflash
But does that sprocket match the drive sprocket, and is compatible with the chain.........they all have to be the same either 35...or 40...or 42.
"a sprocket is not just a sprocket" ( Shakespear ) You can't mix, and match based on cost!
Da redflash
