Amazon shifter kart?
Confused69420
So I'm scrolling on amazon thru the go art section to see what ****y go kart there are and i come across a 125cc shifter kart that comes in a 2 seater variant does anyone have this go kart beacuse there is not 1 video that shows this kart driving?
The 2 seat version has 2 steering wheels! I am dying.
Unbelievable! Well, that's one way to do it. I made a kart that has 2 steering positions for a bench seat (with racing harnesses), but only 1 steering wheel. It does have dual gas/brake pedals though. Harnesses work normal for 2-seat, and flip the inside straps of both for center-drive.
three-point seat belt?
My kart pictured above? My harnesses actually came as 4-points, but for build reasons I put the shoulder straps under a single bolt instead of under 2 bolts. so yeah, 3-point harnesses now. The long reach over the top of the "roll bar" now will keep you in the straps that way. Meanwhile, it helps facilitate flipping the inside half of both to make a single centered harness. "Roll bar" isn't one, just part of the structure. A full rollcage not pictured will be bolt-on-removable for transport purposes (see stubs sticking up from dashboard). Fenders not built yet.
FlyFrog
Kankakee Illinois
  • The two-seat frame is widened and lengthened for better driving stability.
  • In this two-seat version, the auxiliary seat has a steering wheel and auxiliary brake. The auxiliary seat can assist the control, and can press the auxiliary brake to stop.
  • Two adults can drive together, so that two people at the same time to experience the fun of drivering. It is also possible for an adult to take a child with him to ride safely while allowing the child to enjoy the ride.
so it seems the 2 seater has 2 breaks 1 gas and 2 steering wheels, and if anything, would be nice for parts, has a reverse gear neutral and drive, you could definitely build it up or use it to build you own cart.
FlyFrog
Kankakee Illinois
out by me we have a little go cart, quad, dirtbike, mini bike shop with all chinese machines, its nice having them there because i can go get ideas and parts from them, kind of thinking about picking up one of there offroad carts and see how it does, worse comes to worse engine swap it
