EpsilonZero
...still cheaper than a boat!
- Messages
- 395
- Reaction score
- 182
After messing around and modifying the stock axle and front spindles to mount larger wheels, I still wasn't happy. I decided to go for a more standard axle and settled on doing a 3/4" custom job with shaft adapters to mount 1" ID wheels. I didn't go 1" for the shaft because it was easier to source a sprocket and a sprocket hub that I used as a brake rotor (reusing the stock caliper). I also cut off the front spindle nuts and added a washer to reduce the negative camber and get rid of a bit of stock steering wobble.
So, I went from this:
...to this:
...and I made a video showing the upgrades. I have spent a lot of hours working on projects and never tried filming it before now. My three year old assisted with the project, too.
...to this:
