Bushwacker
- Messages
- 12
- Reaction score
- 4
Hello, does anyone have any info about my klipper kart one wheel drive Axle? I would like to make it a live axle
Yes pics do help ,I just got to work on it and was asking my original question before I started working on it.Um...it looks like you already have a live axle (with "step downs")
...see why pics are so helpful?
These pics should have been in your first post![]()
So the whole axle was spinning just the way it looks like, as a live axle, but the right side was made to just freewheel in a wheel bearing? Not sure if I've ever seen that before, would have to really dislike the turning drag of a live axle to do that. If that's correct, you've got your live axle all set and ready to go already. Only thing missing is machining or otherwise carving a keyway into the right end of the axle, and losing that wheel bearing. That, and new axle bearings as Denny said.The right side was turned down with no keyway on it and was running a bearing in the hub.
Correct, I read that klipper kart was made by t&d metals and for liability reasons they turned down axles they had on hand I guess rider's where getting scalped or clothing caught up in it.They also put a square tube on and run the axle through it ,it's making for a ruff time getting the damn thing apart.So the whole axle was spinning just the way it looks like, as a live axle, but the right side was made to just freewheel in a wheel bearing? Not sure if I've ever seen that before, would have to really dislike the turning drag of a live axle to do that. If that's correct, you've got your live axle already. Only thing missing is machining or otherwise carving a keyway into the right end of the axle. That, and new bearings as Denny said.
Yep, that's why my BFH collection is gathered around the vise leg on my bench. 1# claw, 3# mini-sledge, 4# blacksmith's, and a 12# full whammy bad attitude hammy jammy. My builds show me great respect/trepidation/fear.You get to take out your frustrations beating on stuff.
The first link below has a 4.5" brake drum that's machined O.D. for use with a brake band (as opposed to I.D. for internal brake shoes), and it has the standard 6 holes on a 5.25" bolt circle that the split sprockets bolt up to.a hub like the sprocket and brake drum combo I can use for the split sprocket?
BewareI think I need to take a break from surfing the web ,two more followed me home today
