Lawn Chair
karl
North east Ohio
Gettin er ready for a pliance jump. Hip hip.
After I get a new embiggened sprocket in the mail, biggest on hand was 45t, I can mount the axle and send it.
Just a toy to slide around the parking lot this winter on lunch break.
karl
North east Ohio
I always click on your posts to see what you are doing!! :ROFLMAO: :ROFLMAO:
I love it (y)
Thanks! Good to hear from ya!
After getting shipped the wrong sprocket , one return later got the correct part.
Not much bigger will fit , currently 10t to 60t. Fresh #420 chain , ready to rip.
Got it sat on the ground.
No room for foot controls, so throttle and band brake levers will be on the steering wheel,
thinking butterfly type to keep it kart like.
So when’s the first test session? Your girlfriend or wife hast to spend a lot of time with her palm on her face. :smiley_omg:
If you should happen to need a crash test dummy let me know!
karl
North east Ohio
Hopefully soon! You aint lying ! Ill keep that offer in mind ;)
I may steal your oil drain design.
Have at it, got the same setup on one of the bikes, works well.
Taking bets on how long the lawn chain will last? That's some crazy fun right there. ;)
VIDEO PLEASE!!!
I should just keep one on standby. Workin on it!
karl
North east Ohio
Mad steering angle, mario kart. 27mph @3600, and ungoverned. None of the front end
parts including little wonder leaf blower rims, snowblower tires, and homemade spindles + tie rods were ever intended for a go kart much less a lawn chair. But are gonna rip. Actually using legit throttle and brake cables, got the band brake set up. Grips good with light pressure.
Rear end finalized, Once the steering wheel is made and levers mounted, ill be ready to send.
karl
North east Ohio
Throttle lever from cub cadet snowblower steering trigger, check
Bicycle cable and made up linkage, check
Dirtbike brake lever and band brake, check (actually works!)
Super twitchy steering, check
Willing test subject, of course
Contact?
How many of those did you build? They just kept magically appearing from behind the snow bank! How cool! Seriously though that thing is cool and looks like it handles pretty well. What happened to the tillotson?
karl
North east Ohio
My wife and I really enjoyed your video good job.
Thanks I appreciate it!
It's magic! Surprised me, remarkably stable given the wheelbase.
The "fuel injection" carb refused to idle stable and could not get it adjusted right/ had no power.
Cold weather? Partially my fault for not torquing the starter clutch to spec, it backfired while trying to get it
to idle and sheared the flywheel key. So now the clutch is fastened to 50 ft/lbs, and it runs great
with the traditional honda clone type carb.
