Minibike build
karte_m0lim
Birds Aren't Real
Dubrovnik, Croatia
so, as there was lots of parts from past or broken projects , decided to build mini bike ..
plan was to post it in build off thread but as ther is no 2021 , I will psot it here..
as I said , some parts I already have, somo of them are ordered , mostly from China..
karte_m0lim
Birds Aren't Real
Dubrovnik, Croatia
so first started with sprockets for TC... since last time I use it I had few kilos less ... :ROFLMAO::ROFLMAO::ROFLMAO:
also had to make hub for rear sprocket..
karte_m0lim
Birds Aren't Real
Dubrovnik, Croatia
frame... didn't like first version ..
so changed a bit... and then , wheel was hitting a frame (03)...
so changed again .. still going to be tight ..
karte_m0lim
Birds Aren't Real
Dubrovnik, Croatia
I do not like original fuel tank so maybe to use this one (at least to fill the gap between engine and seat)..
karte_m0lim
Birds Aren't Real
Dubrovnik, Croatia
front.. its hard to find "normal" tyre for minibike here so going to use go-kart narrow tyre.. initial paln was to use rear tyre and hydraulic brake but that would be too much wide ..
also , I wanted to have fron susspension, tryed few types, but it's just ugly... so its going to be as on pict 10 ...
P.S. can admin please edit my thread name :p
karte_m0lim
Birds Aren't Real
Dubrovnik, Croatia
not much progress lately..
still lots of welding and grinding ahead...
karte_m0lim
Birds Aren't Real
Dubrovnik, Croatia
fully welded, grinded...
remains to bleed the brakes, put the chain and still waiting for kill switch ...
And we’ve been waiting for you to update us. So now you know how it feels to wait. :roflol: Now when is the turbo engine going to be done for the kart?
Seriously man it’s looking good!
karte_m0lim
Birds Aren't Real
Dubrovnik, Croatia
Thanks guys, regarding slicks, it's really hard to find any kind of small tyre here that can fit for minibike.
Usually, there are scooter tyres, but they're 10" or bigger. and I had some parts from gokart..
Anyway, after the first test ride, engine (tc) alignment wasn't perfect so I redo engine mount and also switched to smaller chain and sprocket keeping same gear ratio. At least, I can lean on left side now (sound so American), leaning on right side is bit sketchy as brake disk hitting ground.
Still have to clean the carburetor and adjust it a bit, as it works on choke only.
