Zheking
Short time reader, first time poster. I'm pretty mechanically inclined, but this is my first toy with a carb ever.
Backstory,
Bought a coleman CT200U used (great price!). would start, and idle, but over 50% throttle would die. Figured ok, just a dirty carb, and since the OEM carb jet has that "anti-tamper" junk, I just went ahead and ordered the stage 2 kit from OMB warehouse that had a new carb / jet.
Put the stage 2 kit on, set the valve backlash for the new springs (Forgot to set it to TDC and the exhaust valve fell down in the cylinder, oops. 4 bolts to pull the head and get it out, took 10 minutes, wasn't that bad), put the new carb w/ new jet on. Exact same problem. I pulled the fuel line off the carb, it's free flowing, and the gas is fresh and tank looks clean. I pulled the bowl, and it didn't seem to have as much fuel as I'd like coming into the bowl, but it reading the reviews / Q&A on OMB's website, no one else has reported a lack of fuel issue with the carb / jet it comes with. To me, it seems like it's getting lean, but since no one else reported the problem and it did the exact same thing prior to putting the stage 2 kit on, I have a hard time believing that is the issue. I did try taping off a lot of the filter to reduce air intake, didn't seem to help. (if the air filter was on the other side I'd drive down the road spraying starting fluid in to try and test the leanness, but it's hard to do with it being on the same side as the throttle). Running with the choke on / off made no difference. Have not checked compression (as my compression gauge has come up missing) and I can't find a factory service manual for this thing to tell me what compression should be anyway. Did put a new plug in it when I put the stage 2 kit on (the racing plug on OMB's website frequently bought with the stage 2 kit)
I've exhausted everything I know to check, and it's hard for me to justify taking it some where when I can get a new motor at harbour freight for $200 (minus 10% coupon they always seem to have), figured I'd check here if anyone had any thoughts on what to check before I just say screw it and get a new motor (or maybe even a little 200CC diesel motor if I can find one!). Thanks.
Backstory,
