karl
Totally not clickbait.
Dumb idea, use blade stop clutch from a honda hrx217 hxa style push mower as a cheap 3d motorsport style manual clutch
And preform mad wheelies and peels???
Took a junk gcv190 OHC vertical shaft with a bent crank, and swapped the crank from a motor that pushed a valve guide.
Then removed pesky things like the governor, dipstick, and oil slinger gear. Drilled and tapped a level and drain plug, trimmed the shroud, and good to send horizontal. 6 whole horses of power. Sprocket will be welded to an old blade.
Honda Roto-Stop® Blade Brake Clutch
Allows you to start & stop blades with the engine still running
Step away from the mower without having to restart the engine
