Covid Kart
Speed Jr.
Bristol WI
Figured I would drop a thread on the kart I built over the last month since we were stuck at home. I call it the Covid Kart. Lol. Enjoy.
https://youtu.be/BjqGo28ABMo
Larry
Speed Jr.
Bristol WI
Awesome kart!! What speed do you get out of it?
What batteries and controller are you using? Gearing?
Thank you.. So far its running around 55mph. Curtis 1236SE controller, ME1507 Motor. I'm running five 16V Antigravity VTX-20's. The controller has the motor speed limited to 4000rpm. I have a programmer on the way to turn it up. Running 40 pitch 20T on motor, 45T on axle.
Nice kart :thumbsup:
Um...a 20T to a 45T is like 2.25:1 :huh:
…& in the pic (above) it looks like there's a 16T drive sprocket
…& the driven sprocket looks a bit bigger than 45T too
Speed Jr.
Bristol WI
Yes, in the photos I had a lower gearing. I have since change the gearing probably a dozen times. I event went to a 22T drive sprocket and 42T axle sprocket, but was a little tall. Right now the 18T/42T is the best all around setup. Enough torque to blow the tires out and still decent top end. After programming its running at 65mph with great acceleration.
Larry
Bmr4Karts
Larry
Your conversion is awesome.
