Carter 24995
jawarren77
Edmonds, WA
Updated photos
Got this 2 years ago and been sitting in the garage collecting dust. Figured what better time then now to get it going.
Picked up a Tecumseh engine from my neighbor. Has a clutch and sprocket .
The plan is to sand it down, paint it, get wheels/tires and sew up a new seat, then get the kids on it!
jawarren77
Edmonds, WA
Alright, been doing some sanding and painting of parts and figuring out the motor. It has an 11T sprocket on the clutch and is a #10 chain. What would be a good wheel sprocket for it? Will mainly be me taking the kids around until they feel comfortable driving and stopping themselves.
jawarren77
Edmonds, WA
OK, I need to know what type of chain I need to get. The clutch has an 11t sprocket on it. My neighbor (wheel supplier) has a chain that fits it, but we can't figure out what type, number it is.
links are 3/8" center to center.
JTSpeedDemon
2019 Build Off Winner!
Texas
You need #35 pitch chain. :thumbsup:
---------- Post added at 03:13 PM ---------- Previous post was at 03:12 PM ----------
Also, would you mind uploading your pics directly to the forum? I don't go to third party sites much, partly because my computer's a bit slow.
Here's how to upload pics: http://www.diygokarts.com/vb/showthread.php?t=737
Are those harbor freight wheels. If they are, yo will have to change them. They don't last more that 2 seconds. Hub is thin and there are no bearings. The wheel will fail. Guaranteed
JTSpeedDemon
Texas
Note that he said the HF wheels are just to get it off the ground. :thumbsup:
jawarren77
Edmonds, WA
I noticed on the stock PDF I found on BMI that the stock chain setup is a 10T clutch sprocket and a 60t on the wheel side. My clutch has an 11T, if i plan to keep the stock tire size what sprocket should I go with?
---------- Post added at 09:20 AM ---------- Previous post was at 09:17 AM ----------
Fixed the photos for you!
JTSpeedDemon
Texas
It depends, do you have an axle hub that will fit that? Is the band brake positioned so it can be that close to the sprocket? Ya gotta take a lot of measurements, we can't do that for you.
jawarren77
Edmonds, WA
Here is the motor mounted and the space I have. Would a band brake on the clutch be a better route?
JTSpeedDemon
Texas
I'm thinking that side bolster will interfere with a brake rod, IDK. You really need to take measurements.
As for a clutch brake, I would not recommend that, because then if your chain pops off, you have no brakes!!
Also, by my reasoning, you'd be trying to stop something that's spinning about 6 times faster than the wheel.......
jawarren77
Edmonds, WA
Thanks JT, I am totally new to this and know just enough to get into trouble. The frame came with a rod and brake band. I just have no idea how it was attached.
