From your description, almost impossible for most folks to tell.
If I were you, even if I got some answers, I would want to check the fit in the real world, so I would assemble the whole rig right down to tightening the bolts to proper torque, but before buttoning it up I would roll out a layer of modeling clay and put it on top of the piston. With the whole thing ready to crank up, I would turn the engine over a few times with the starter rope, then take it back apart and get a really good sense of how far the valves would miss the piston. If the thickness of the clay between the valve and piston is to little to assure you of enough clearance, you need to start over.
Do NOT forget that at high speed the clearance will almost certainly be less, NOT MORE, and you only get one chance to save all of those expensive parts to fight another day.
Wishing you the best of good fortune in your experiment.....Joe
