DirtyDogs446
- Messages
- 70
- Reaction score
- 1
Wow that is great info thank you I did grind down valve cover I'm not sure what the sound was so I had the 5.26 also. I wonder I'd there is a size down from thatI just installed 1.2 ratio rockers from arc and they're site says to use 5.26 height pushrods, stock are 5.54. Also you need to clearance the valve cover for the rockers as well ( could be the tapping noise). I'm using the thinner metal gasket and the 5.26 rods are perfect. Also using the s.s valve kit with 26 lb springs. CM grind cam
I see you milled the head and are using a thin gasket so your rods are definitely too long .![]()
Sent from my SAMSUNG-SM-G930A using Tapatalk
