budget wooden go-kart
They are no more unsafe than yours..
One could argue that they have more safety installed in them as they are just meant to go down hill, have a proper steering, braking and usually have a steel chassis of some sort...
I kinda beg to differ....
Mr_mcrib212
Inmate #2148
Southern California
and also building a roll cage if you make it out of metal, mine was wood and almost broke me neck
---------- Post added at 01:39 PM ---------- Previous post was at 01:38 PM ----------
ill make a post about that other go-kart
Mr_mcrib212
Inmate #2148
Southern California
So that would not be overkill or I should NOT do it
---------- Post added at 08:10 PM ---------- Previous post was at 08:09 PM ----------
:feedtroll:I'm guessing I should not do it
Mr_mcrib212
Inmate #2148
Southern California
I have heard of guys putting 670cc predators on lawnmowers and they go 65 mph, sketchier than mine?
---------- Post added at 09:19 AM ---------- Previous post was at 09:14 AM ----------
Actually I changed the gear ratio to 6:1 so I have a better top speed:auto:
Well then quit gabbin..... keep building then...
You already think this is a joke and safety isnt a concern of yours... so
Ironically now... youll get more help at the veterinarian hospital (if you can find one open, that has been made essential) than an actual hospital....
After this this lets loose.. someone might need it...
Mr_mcrib212
Inmate #2148
Southern California
oh safety is a concern when I get enough money I'll install some sort of harness and/ or a good helmet so I don't crack my skull open when the harness breaks
Ohhhh of course.....
Righttt... a safety harness... can't for get about that right......
Let me guess... your going to make a cage out of 2x4's aswell... for that harness...?????
Solomonster212
High Compression Member
Hoover, Alabama
When exactly is "oil change on time" I've heard 6 months I've heard a year I've heard every month and I've heard every 10 hours of use, my last oil change was a couple months ago
Whenever the oil gets dirty. You can check it for a reason.
---------- Post added at 02:51 PM ---------- Previous post was at 02:49 PM ----------
this is the best motor ever
The Hemi version would'v been better. But I guess you don't need any extra power to push a lightweight wooden kart, right?
---------- Post added at 02:52 PM ---------- Previous post was at 02:51 PM ----------
Electric = motor. Internsl combustion = engine.
Brianator
Gettin' er done!
Barrie, Ontario, Canada
Forget the harness, it's best you get tossed from the kart when you Evel Knievel it and it starts cartwheeling! Find a football uniform (including all body gear and a helmet), that way you're protected, it will be darn near impossible to identify you when someone calls the cops plus you'll look the part! *insert socially frowned upon term of your choice here*
Good luck buds you're going to need it!
Mr_mcrib212
Inmate #2148
Southern California
The problem is, I was going to pick up a frame and then all America got quarantined
---------- Post added at 08:03 AM ---------- Previous post was at 08:03 AM ----------
It was a freaking yerf dog for 100 bucks
