Help with my snowmobile engine on kart build.
Speedy79
Ferriday, la
HI I've been working on my project for quite a while now.. The problem I am having is with the clutching. When starting my project I knew nothing about cvt and thought I could just run the belt straight to the axle. Bad mistake. Cause I trashed my secondary and gearing not knowing I'd need them. I recall reading in one of these post a while back about a adapter I may could buy or build to replace my prI'm art with a centrifugal or something and just chain down from that straight to the axle.? Please tell me I'm right and if so does anybody know where I could buy one? Thanks in advance!
karl
North east Ohio
Year/make/model sled?
How heavy is this kart? What is the intended top speed? What terrain do you ride on? Tire size?
But, at least a pic will help us judge :useless:
I would look for a used replacement driven clutch, and research jackshafts and ratios some.
uhoh..
yes, we need pics to help..
engine, TC, (both pulleys) and general setup..
the more info we have the better; as karl said: engine details, wheelsize, weight, intended speed and so on.
ruining the driven of your TC might have been an expensive test..
I assume the sled came with a salisbury style TC (duster 94.. 900 series something alike)
and a driven for that can set you back several hundred bucks.
Sooo I really hope you haven't actually trashed the secondary (driven pulley) but just upset it slightly ;)
That way we can replace just parts not the entire unit ;)
But we need pics to judge
Speedy79
Ferriday, la
Yes I'm afraid I have thrown out my secondary. I started this build about 6 months ago and me not knowin little or nothing about cvt set up's did the worst thing that could happened I guess now. The sled was a 1979 Artic Cat Pantera with the Suzuki spirit 500Fc .. After watching and wanting for so long to have one of my own buggies that would rip I decided to try and build one. ( shoulda studied a little more I see now). I ran across this frame online that had this Jacks haft setup so I figured it was my cheapest and best route. It had the driven off a 30 series torque converter on it and I figured what the he'll so I gave it a shot. It lasted for a while and was actually pretty fun. Not no where neAR the speed of the sled though. Needless to say I've been through about 3 30 series clutches in about 3 months. After reading over and over these post night after night searching for a answer I finally just decided to ask for help. I'm willing to speND a little more money on this project if need. I've got a few driven clutches off Polaris motors. Would they posibly work? Do I need to ordetermine the original driven and shaft for the sled? Do I need the Geer box also or can I get by without it? And last I read on here this guy makes adapters to run chain straight from the drive of the motor, if so is there a way to get intouch with him? I'm here to listen please help!
---------- Post added at 02:57 PM ---------- Previous post was at 02:56 PM ----------
And howe do I post a pic?
:huh:
karl
North east Ohio
I had an 85 with the spirit, it was a dog. Struggled to go above 40mph, even freshed up the top end, did not help , 300 yamaha left it in the dust
As far as the clutch, you definitely need the belt style clutch.
When you say hook chain to motor, I think you mean a normal style, 1 speed , centrifugal clutch
This is not ideal for a heavy yard kart, the gear ratio would need to be very steep to not burn up the clutch, so it will be really slow. Also the clutch will be expensive , and custom made for the right engagement speed.
So I would keep a lookout for the matching clutch off a simular sled, at least the same belt width/ dia
As far as the way it could be mounted, that is determined by the way the spring is wound / buttons. Most sled driven clutchs are not reversible.
Anyways, I used an old sled's driven clutch on my go kart build, this is how I did it.
Speedy79
Ferriday, la
Does anyone know about this ttype of setup? I've messaged the guy but still hasn't responded. If so are they any good and where could I purchase if so.Thanks in advance
Karl where did you get your shaft for your secondary? Is it splined?
Bret made the adapter himself.. you can't just buy one I'm afraid
you have half a sled CVT.. I just can't identify make or model from that angle really..
(I have a feeling.. but that should've holes.... IDK)
could you take some better pics please?
Speedy79
Ferriday, la
Let me know I'd need more! Thanks
yeah I'm afraid that looks totally unfamiliar to me..
so stock arctic cat part# is the only way to go (for me) currently..
part # for the driven clutch would be 0226-022 (allegedly the same as for the Lynx)
https://www.alssnowmobile.com/oemProductParts.aspx?ps_OemSku=0226-022
Or if you have a Panther not a Pantera.. 0226-019 (different fixed sheave with brake disc mount afaik but perfectly identical driver clutches [0225-121] )
https://www.alssnowmobile.com/oemProductParts.aspx?ps_OemSku=0226-019
IDK how "good" those used ones are, but since there is essentially not many options left..
I'd pick one (the "ok to ship" -022 I think)
Sorry... the clutches have been replaced by the Comet 108EXP and that is easy to find
but I unfortunately don't know if the two are fully compatible.. and since a 108EXP driver costs ~500 bucks new, I doubt you'd want to swap, right ;)
Ext580
Sacramento
If you eventually get the correct secondary clutch, which I highly suggest. You will need to correctly set the center to center distance and offset. If you are using a pantera then its 12.2" center to center. And 34mm offset. This will ensure your belts last and dont shred everytime you go out. I have a post showing my motor swap using a snowmobile engine. Its still in process but I might help you understand the set up.
Old guy
Karl I bought a cart with a sled engine on it a john deer 440 liquid cooled it has the same looking set up you have pictured above on mine the driven clutch is running backwards from the original rotation and seems like it's chewed up the ears on the angled pieces that slide to open not that famililur with cat terms it seems like it's not opening up don't know if is just worn out or if you can run a driven clutch either direction some one please help
---------- Post added at 10:03 AM ---------- Previous post was at 09:57 AM ----------
And since I did not build this cart I'm not sure if. He has them spaced correctly or off set correct can you run a snowmobile driven clutch either direction
Muddstud
British Columbia
Im just starting a build on a 79 oddy, i got a 340cc Arctic cat to go in , started with mounts for the engine , got it mounted and was going to figure out jack shaft and sprocket sizes when my brother said i should just keep the reduction box with the secondary off the fl250cc in it and use that because the drive axle has splines on it and it would save me from having to redo an axle and build a jack shaft . I was concerned about that secondary not working with the primary for the A/C 340cc properly . My brother asked me why it wouldnt work ? I didnt have an answer for him ... any help would be greatly appreciated
Start a thread of your own and ask away. You will get more interest that way
