Fairly quiet, yet 99% unrestricted exhaust: I custom built one with an educated guess after drawing it up as a schematic plan on a notepad. Uses the basic principle of noise-cancelling headphones, that matching sounds running into each other will cancel each other out. Mine has 4 full 180-degree switchbacks in it, with the sound bouncing back and forth off the 5 bulkheads from start to exit, but so oversized that there's basically no restriction at all. It's on a hot-rodded up Predator 212cc motor, where it comes off of the head's D-shaped exhaust port with a 1" round tube that covers the entire opening, then angles away about 4" long to the side of a 3" I.D. length of car exhaust piping, right at the beginning of it. Total length without the rectangular box tip at the exit is 13". There's a 1&1/2" expansion section to start, then a 5" resonator section, then another 5" just like it, then a final 1&1/2" section to center the exit flow. The sound is a deep rumble somewhere between a lawnmower and a leafblower, but the power basically doubled immediately, even smelled raw gas in the exhaust now, has more than it can even burn until I advance the timing 8.4 degrees (next mod). Hi-flow cone air filter, billet venturi intake, and racing carb jets weren't being allowed to perform when factory exhaust was in place, so all the mods suddenly starting working when new exhaust was fired up on this custom minibike, doubled the power, kept flipping over backwards, snapped the chain, crazy. With CVT (torque converter) and pushing at least 12 hp. plus, it's just too stupidly powerful and dangerous to really ride, even with the built-in adjustable wheelie bar. Exactly what I was trying to build!!! Took a year, scratch-built from raw plate steel and tubes. Only wanted to build it, not ride it. Plan to sell it, then do the same thing scratch-building a track/trail wheelie-popping go-kart. Note: Used about half a tube of welding rods on that exhaust system!
