Just bought a use Baja dune 150cc gokart and trying to figure out how to get it start. It’s missing the key and the battery seem to be drain. I jump start it and open up the ignition switch. I connect wire 1 and 2 together while tapping on wire 3, nothing happen. I test it out with a voltage meter on the ignition wires to make sure it’s getting power but it’s not showing enough power. I make sure the jumper that’s connect is supplying power and there’s no short on the wire, the meter read over 12v. I also check the kill switch and unplug it to make sure it’s giving power. I try stepping on the brake to get it to start thinking that might engage and give it power but didn’t work. I don’t know what’s wrong with it but it’s not showing any power on the ignition switch or have any sparks when the wires are touch. Can some help me? It’s a Howhit 150cc engine, I research it and it’s basically a Cy6 engine.
