So I have a not so stock predator 212 that is dumping fuel out of the carb. The engine has a billet rod, billet flywheel, advanced timing, race prepped carb, 18lb valve springs, intake, and header exhaust. Engine runs great and strong. I’m running a Walbro pulse style fuel pump with it. I have cleaned the carb and I know the float is not sticking and that when closed the plunger works great. Last night we had our first big race (we started a little track at our family land) and out of 9 karts, 3 were running these same fuel pumps and all 3 were dumping fuel. Mine and 1 other engine were modified and the 3rd was stock except the gov was removed and was using the fuel pump. We are all new to this so excuse the ignorance...but is there something we don’t know about using a pulse pump with a predator engine? We are all fairly mechanically inclined but this one has us stumped. Is it possible that the small spring on the float needle isn’t strong enough to close the plunger under the pressure the pump is pumping fuel in??
