Trying to figure out what brand my gokart is
Akeymard
I Bought two karts yesterday ones running but the other needs front suspension and I can’t find this model anywhere. I want to get the right A arms and springs for it but don’t know where to start.
Akeymard
It’s very possible that those are different shocks than the originals. I can get some better pictures this weekend. I dropped it off at my camp.
Akeymard
Here’s some more pictures
bthompson224
DFW
Yeah, that rear suspension is homemade. Not saying it's bad, but makes ID harder. You can see from the missing paint it was welded later, and they probably heated the pipe to make the bend (more missing paint). And SpeedCo appears to be correct on the frame ID.
5814SpeedCo
Fort Worth, TX
It's not a bad concept on the rear suspension but I'd put it more at a forward angle. The way it sits now you're going to get a bad pogo effect, not ideal!
950speed
Texas
Not contradicting, but I’m thinking about this, because those shocks appear to be either fluid or gas shocks, so I would assume there would be some dapaning,
But would it still be pretty bad?
5814SpeedCo
Fort Worth, TX
Considering just about all suspension you see that have that style shock on go-karts, quads, motorcycles are typically at an angle it would be best to have them angle more. The preload will compress harder and faster, which if you are driving it off-road means it's more than likely going to bounce the back end around more. Shocks are designed a specific way. Just like on a Harley when you use and lowering link it sets the shock at a totally different angle, which from experience usually makes the shock perform totally different.
I Bought two karts yesterday ones running but the other needs front suspension and I can’t find this model anywhere......
It's a Murray.
Not sure which model but it's somewhere between an Explorer and a Kilowatt or may be modified or a Frankenkart. Maybe someone else can narrow it down.
