Scrap Pile Kart- Part 2
Bigpat5123
I am back. Didn't end up finishing my kart last year mostly because I was unhappy withe the end product. I decided to go full suspension as I am too old for a solid rear end! Also I am going bigger as the 205cc was just not enough once I added the 18" rear tires for ground clearance. Found a great condition Briggs 8hp (319cc) to push this cart along. Here are some pictures of the rear suspension setup that I made last week and how she sits now. Also a pic of where I left off last year. Will keep updated as I finish.
JTSpeedDemon
2019 Build Off Winner!
Texas
Hmm, well, uhm, hmmmm...
That's a *cough* interesting roll bar you have there.
I like your choice of a Briggs 319!
Bigpat5123
So got the Briggs mounted up to find out that it will need a rebuild this winter. Guess that's what you get for a cheap craigslist purchase. Anyway, had a 7hp Tecumseh sitting around that I knew was good so I mounted that up. Got it doing 28mph with about 450# gross weight. I am ready for sanding and painting, added some mud flaps for fun. I will post up when the paint is done.
Awesome!!! So the first test drive was good?
Bigpat5123
Landuse, I have had a bunch of test runs since I started building the kart. I have changed engines 4 times and changed brake setup a couple times. I will probably change something before I am done lol
What a weird looking throttle setup....Them tec's and some briggs... just unnecessarily complicated....
Oh... a point of concern..... You shouldnt have a Lap belt without a Proper roll cage......
Your supposed to be thrown out without the machine landing/staying on you, while underneath...
Bigpat5123
Yea it looks more complicated than it looks. Easy way to make a winter motor into a small season motor.
I had a roll bar on it but removed it while modifying the cart. I am unsure if t will go back on.
