40 Series backing plate alignment
Aircomet
Knoxville, Maryland
I know one of the new products that is becoming increasingly popular is the 40 series tc with backing plate kit originally made by gopowersports. Now I see other companies are jumping on the bandwagon on eBay. But one of the major drawbacks I see with this setup (apart from $$$) is the belt alignment issue generated by mounting the driven outboard. This throws the alignment off by almost an inch during shift out.
But, one way I thought of that might solve this would be to mount the drive clutch backwards. This way both clutches now shift in the same direction and belt alignment should be okay. Just wanted to run this by you guys and see if I’m missing something here. It just seems like a simple solution and I’m curious why it hasn’t been thought of. Here is a picture I found showing what I mean.
Snaker
I say by all means give it a try. I don't know if all these Comet and replica's and copies have the same dimensions so it is up to the installer to determine if it will mount properly backwards. It doesn't matter for user function.
The obvious best fit on a symmetrical CVT is having the pulley's fixed sheaves on opposite sides of the belt, one way or the other. The backplate gets in the way when mounting the driven pulley with the movable sheave inboard. I believe that is why the manufacture's use a asymmetrical design for the 30 series incorporating the backplate. That allows both pulley fixed sheaves to be inboard. Problem is the belt grip has to be less than that of a symmetrical design, which would also limit the power transmission of that design.
Also, don't underestimate the benefits of having a backplate. It alleviates installation difficulties such as center-to-center dimensions, belt length, pulley parallelism, pulley lateral alignment. All that is done for you.
67StingrayJ
You have a point there. That is the sole reason I initially opted to go for a 40 series with the backplate. I still believe it's possible however to mount the two pulleys correctly and utilize a back plate. I intend to give it a try soon.
67StingrayJ
OK guys, question. Can I have the drive pulley mounded reverse with appropriate spring?
40 series driver pulleys do not care which direction they spin in order to engage the clutch or contract the sheaves..
it'll work as well CW as it would CCW
LightningTeg
Can confirm the driver can be mounted either way but it depends on the kit you got. The picture in original post shows the kit where driver must be mounted inboard.
