predator 420 lighting coil
J.S.@SMS
Road Hazard
Weeki Wachee Fl.
Run the lights off the battery. A 420 predator has a charging coil for the battery, so the easiest thing to do would be to run the lights with a switch off the battery.
67StingrayJ
Not a bad idea. But I read that it only puts out a max of 3amps and I think I could drain the battery faster than the thing would keep up. Has anyone ever ran lights off the 420 predator before? What did you do?
Bansil
Painter of gnomes....
Just use leds
67StingrayJ
LEDs that use minimal amp draws. Most should be in the hundreds of milliamps
I'm way over budget on this build as is and want to utilize the lights that came with it thing. Not to mention I just painted and clear coated the thing and don't really want to do any modifications to the frame. The engine on the other hand, I'll happily modify. Don't they sell a lighting coil for this engine? Has anyone ever used one? How about an alternator?
The coil should be on the engine already stock from the factory. It should be about 3amps. Not sure what other existing ones could fit on there. Anything more than 6amps I think needs a different flywheel. Not sure if it's possible to order an 18amp one from a Honda GX390 with a flywheel and install it.
A car alternator/generator can work, but it would have to be hooked up to the axle with a pulley, or on a jackshaft. A GM AC Delco 10si is quite popular as is the 3 wire 12si.
67StingrayJ
ok. If we keep this post open for a while, when I eventually get some other issued sorted out I'll come back to this and give everyone an update. This thing will eventually be my kiddos kart, and it's legal to make these street legal but that means head lights, horn, signals and break lights. Most of these were on it before but with the new 420 engine all the electronics are gone. Unless I can salvage the electronics in some way or form?
If I recall what was mentioned a couple weeks back, threads will stay open until about 3 months of inactivity, before its locked. If it does get locked (from inactivity), just message itsid, landuse, or any other moderator or even the forum admin robertdjung and they'll unlock it for you.
What electronics are missing exactly from the engine or kart?
Correct! I think it is six months though (cannot remember with this "just woke up" brain). We will just open it again if you ask
67StingrayJ
Really, I just want to utilize the original head lights and brake lights. It gets hot here in the desert so we do a lot of night riding when things cool off so maybe a cheap light bar down the road. But for sure, the brake lights, tail lights and headlights are priority.
You might be cutting it close with running all the lights. It might be a combined total of about 5 or 6 amps with the tail light and head lights on, but you should be able to get enough run time with the stator and battery to make it worth your time. May need to hook up a Volt meter to your kart to monitor battery voltage. I'm actually waiting to see if and when Greg over at Red Beard's Garage adds a larger stator to a Chinese clone engine, I'm curious to see what can be added on without too many issues.
67StingrayJ
yeah, that would be ideal for RBG to show us how to do. These threads can only go so far and do so much. I was wanting to do other things to my ride like a tachometer, and a fuel gauge. Ya know, for learning purposes mostly for when I end up building my dream buggy. Might as well add battery voltage gauge to the list.
I believe Grant (Kartfab) did a write up on how to do an automotive style tach. Otherwise I know that the tachs that also have an hour meter built in, just hook on to the spark plug. It's not very fast to update, but its semi decent.
