67StingrayJ
- Messages
- 73
- Reaction score
- 0
Any ideas?
Run the lights off the battery. A 420 predator has a charging coil for the battery, so the easiest thing to do would be to run the lights with a switch off the battery.
LEDs that use minimal amp draws. Most should be in the hundreds of milliamps
The coil should be on the engine already stock from the factory. It should be about 3amps. Not sure what other existing ones could fit on there. Anything more than 6amps I think needs a different flywheel. Not sure if it's possible to order an 18amp one from a Honda GX390 with a flywheel and install it.
A car alternator/generator can work, but it would have to be hooked up to the axle with a pulley, or on a jackshaft. A GM AC Delco 10si is quite popular as is the 3 wire 12si.
If I recall what was mentioned a couple weeks back, threads will stay open until about 3 months of inactivity, before its locked. If it does get locked (from inactivity), just message itsid, landuse, or any other moderator or even the forum admin robertdjung and they'll unlock it for you.
What electronics are missing exactly from the engine or kart?
You might be cutting it close with running all the lights. It might be a combined total of about 5 or 6 amps with the tail light and head lights on, but you should be able to get enough run time with the stator and battery to make it worth your time. May need to hook up a Volt meter to your kart to monitor battery voltage. I'm actually waiting to see if and when Greg over at Red Beard's Garage adds a larger stator to a Chinese clone engine, I'm curious to see what can be added on without too many issues.
