Frame identification
Mick13
Plum
I’m new to this sport and bought this frame but haven’t a clue what it is and why’s the sprocket on the other side. It’s yellow up front and green in the back. I have a gc160 motor but probably going bigger. Thanks for the help
Mick13
Plum
My 11 year old and my self are excited to get it on the road. Would you guys suggest a cvt since it has such large tires or will a clutch do. I a couple years I’m thinking about a raptor 350 motor and a real clutch.
Budget GoKart
Aka a kenbar
roachdale, indiana
A clutch will work and will be cheaper but a cvt will give it more torqe to climb hills and be a bit tougher i got stuck with my yerf dog in grass it has a clutch
JTSpeedDemon
2019 Build Off Winner!
Texas
WHOAWHOAWHOAWHOA, hold you horses! Let's not get the poor guy confused!
Yes a TC will do better on hills and
stuff, while also giving you decent top end, because it has continuously variable belt ratios.
But a CC can perform comparably well on a hill as long as it's geared low enough. That being said, you will lose top end as you gear lower.
And a CVT(Continuously Variable Transmission), does NOT produce torque, but it, in a way, "magnifies" the torque, so it puts less load on the engine.
And a kart with a TC can get stuck too, there are too many causes to list here.
Mick13
Plum
May rzr 800 has a cvt and when I went from 25” to 28” tires I put a dalton adjustable clutch kit in it. Nice piece easy to adjust the weights to react quicker. Think a 30 will work or should I go for the 40? It will be in the grass at camp and won’t have many hills to climb. We’ll ride the quads if we need to go anywhere rough.
JTSpeedDemon
Texas
You said a GC160 engine? Honda, right? If it's a Honda GC160, it'll be ~ 5-6.5 hp, so a 30 series torque converter should work.
The real deciding factor, is the diameter of the crankshaft.
3/4 in. diameter = 30 series TC
1 in. diameter = 40 series TC
It's simply because of the shaft size that decides which kind of TC you need.
Dingocat
Broke
NE Ohio
There's 1in. 30 series drivers. They exist. 30 series is rated for like 8hp though. So no 13 hp with a 30 series🤷*♂️
Totally incorrect. You can get 30 series TC's with 1" diameter bores as well. It is the HP that determines which TC you get
And the magnum 44c driver is practically a 40 series driver for a 3/4" shaft.
And that again is incorrect!
the 40 Driver is available in two bore sizes (7/8" and 1")
and the 44C Driver is available in three (3/4", 1" and 1 1/8")
both use the same belt but are otherwise completely different.
Mick13
Plum
So I got the axle out. 60 tooth with 20” tires. I may make a new key way and move the sprocket over
