Questions about ratios
rdhdfmn
So I have a question about the correct ratio for my go cart. I read a post about 6.6:1 is a good ratio to go by. Does that apply to all engines and all carts? So for my build I have a yerf dog( not sure the model) with a 60 tooth sprocket on a live axle (both wheels turn when the sprocket turns). I have 18 inch tires on it. I’m building it for me and my grandsons, I’m 265 and they are still young but I want to be able to ride it with them when they get older. I have a Honda GX340 I’m putting on it. From what I have been told I’m going to put a 40 series torque converter on it. Thanks
You can then still use the 60T sprocket you have and maybe go for an 8 or 9 sprocket on the TC. A 10 should work too, but smaller gives you more torque. You tyres are on the large side, so I would go with the smallest TC sprocket you can get. With grandkids its not going to be about the speed
They will enjoy it more if it does burnouts, donuts, and wheelies. :cornut:
Thats what I mean :D To get all of those things you are going to have to gear lower (doing the things I mentioned above). Speed might be scary for little ones, but burnouts and "push your head into the seat" acceleration is probably what they are going to enjoy
rdhdfmn
Thanks for the help guys. Yes, we um I mean they need to do burnouts. So how low would you go?
Tpdingo
Bellmore, NY
Well there is a point where the wheels have so much torque but they aren't spinning fast enough to do much.
For burnouts.....well even a 4:1 ratio would work if you put water on the ground :p . Really if you want to have fun sliding and drifting and what-not, put some water on a driveway and go to town. Its worth it.
For flat ground drifting and meaty 18" tires and a combined weight north of 450lbs....well your talking probably 8-9:1 ratio with a TAV. That gives a theoretical 450ft-lbs of torque at the rear wheels...which should break them loose. I know my kart has about 100ft-lbs at the rear wheels and it will spin them on driveway and smooth pavement but not concrete...with a total weight around 230lbs. But also consider....do you want to spin the wheels EVERY time you floor it? And you'll go down to 22mph max speed with the governor.
