Uh I hate poti throttles..
Anyways.. great katr you got there..
I hear it was quite a blast ... I hope you can get it to be just that again.
You still have the body kit right?
(otherwise it'd be difficutl to replicate the original look)
Anyways
One or two things you should be aware of howevre:
If you power it with Lithium cells (which is in fact a good idea if you can acquire a large enough pack IMHO)
Make sure to not charge it via the onboard controller,
Chances are it's not set up for modern day Lithium cells but at best the olden ones.
And the charging circuit embedded into the motor controller (in case there is any in the first place)
might not be up for the task
Second: be sure to check all wiring THOROUGHLY!
a 72V system (especially since those are DC motors)
will pack quite a punch and a few hundred milliamps are enough to kill you in an instant
(yes MILLIamps!)
if you'e lucky the shock generated by full Amps keeps you alive (weid.. I know) but some aren't lucky in that regard.
Sooo sufficient wiring insulation is key to personal safety.
Do not take any shortcuts or risks for that matter!
Make perfectly sure all wiring is safe AND CORRECTLY INSTALLED.
a bit jealous in fact..
it looked cool and if it's as nice as the internet wants me to believe it was...
I'd love to get a chance for a lap or two;
So prepare to take good videos of you driving it, so that we can be reaaaaally jelly later on
