I dont think they are on the shroud like they are supposed to be!Ray, Give me the model numbers of your twin and i can tell you the displacement.
i think i already spent way too much money... on something that i know will not work lol
oh! oh! yesterady i got the mini yellow air filter to put on the valve vent tube lol!
compensating much, eh? lol
What are you running for an oil pump?
is that a slide carby? coz if it is then be careful coz they tend to suck open under boost leaving you stuck on full throtle!![]()
rotaries are a better engine in terms of performance FACT. they dont loose that 50% or so power in turning a recipricating force into a rotating one, they fire 3 times for every revolution of the rotor itself and for every revolution of the rotor the "crank shaft"
does 3 revs, rotories are a beutifull design if it wasnt for one big flaw, and that wear but we dont have rotaries on our go karts so theres not really much point in going on about them in the supercharger thread unless you want a rotary supercharger? now that would be awesome! if not a little in efficient......
what about throwing a small turbo at this
You will blow the little Chinese engine to bits!
A tiny tubo would work on your opposed twin. Whats the displacement?
, it worked quite well aparentlyI did this to mine: http://www.youtube.com/watch?v=lu5r2vlbTt0
Works well, adds quite a lot of power, gives it more acceleration anyway.
rotore, you would neva get a turbo that small! you'd have to get it to rev to 10k+ for it to spool, find a crashed peugeot jetforce compressor with a super charger, thier a 125 that came with a supercharger from the factory, it worked quite well aparently
