I believe I can buy a reverse action spark plug thread tool to save me from taking the engine apart. My spark plug is 10mm wide but they only seem to come in 12mm. Would it still work. Thanks
I've never used the reverse action method, but it sounds like a good plan when not removing the head.
But something else that might help:
Is to thoroughly drain the engines oil first, then remove the engine and position it upside down; before drilling/tapping. This would allow gravity to help keep even more of those metal shavings out of the combustion chamber...
And then before you started drilling, I'd spray/clean out the whole inside of the combustion chamber with the straw on a can of Brake cleaner. Sprayed in, and allowed to drain back out through the spark plug hole...
Then let it all completely dry out inside for an hour or so before drilling.
That way, you'll be removing the sticky oil from the surfaces of your combustion chamber; and will be able to use an air-blow-gun to hopefully remove more of the metal shavings from your combustion chamber after your all done drilling/tapping.
At that point, you'll definitely want to pour a teaspoon of motor oil down through your spark plug hole, and rotate the engine around & over; to pre-oil the entire cylender wall, before attempting to start the engine...
Oh yeah, and don't forget to purchase a brand new spark plug, and refill the engine with fresh oil too...
PS:
Also, pick up a small tube of Never-Seize from any auto parts store; and smear/coat a very small amount all over the threads of any new spark plugs you ever install. That'll help insure that you'll never-ever have to go through all this again...
