Need Help
GeeZis
Las Vegas
May someone help me out on how to connect this throttle cable to the butterfly.
GeeZis
Las Vegas
May someone guide me on how to tighten the breaks more because when I push the brake pedal, it doesn’t brake as much.
gr8hairy1
Waycross, GA
Some more details would be helpful.
What kind of engine is it?
Can you post some other angles of both areas as well as some pictures not so close?
GeeZis
Las Vegas
Okay here are so more pictures. Both Of The Engines Are TECUMSEH OHH60
Joe-405
Enjoying New Projects
U.S.A.
First picture ——. You have a linkage between the carb and engine block for the cable (I can see it)
Second picture —— try taking the pin out pulling the rod off and just tightening the tension by twisting the piece on the threaded rod. And check your brake pads while your there to be safe. You can also ditch the spring and make it solid and it will stop better also.
GeeZis
Las Vegas
Okay Thank You For The Information but I’m still rather confused on how to connect the throttle cable on to the butterfly ?
Joe-405
U.S.A.
Look between the carb linkage and the block. I can see part of the linkage in your first picture. Top of carburetor there is a little short rod going to the linkage behind the carb. Follow it and the cable attachment should be in the end of it.
If I'm not mistaking that's a Tecumseh Powersport..
DO NOT connect the throttle to the butterfly if the governor is still installed,
instead connect it to the levers that go to the governor
there should be plate beneath the carb and a lever on the flywheel side..
take a pic of those and we'll tell you where to connect (since I don't find the manual atm)
[EDIT]
Oh found a 'spring' pic..
see the clamp on the right upper corner of that pic with the brass screw?
that's where the cable sleeve rests
And you also see that footshaped lever (above the 'Tang' label in the pic, with the drilled toe)
that's the part that needs to be actuated.
easiest is to slide in a barrel shape cable end (needs to be large to lock in properly)
into the large hole right next to it (it's the same piece)
[EDIT II]
Like shown here (it's a blurry pic but you get the idea):
For the brake:
most common cause for sup-par braking power with a single piston caliper like yours is
- apart from a worn down puck - the caliper bracket
Or rather the caliper not allowed to move freely inside the bracket to align with the brake disk.
since that literally cuts stopping power in half
(only one puck rubbing against the brakedisk instead of both)
Atlanta, GA
Do all this. Then take the carb apart and clean it thoroughly. Ride for 20 minutes.
GeeZis
Las Vegas
Okay Thank You To Everyone For Helping Me Out! So I’m pretty sure that I have the governor removed. So I just have to connect the cable straight to the butterfly ?
gr8hairy1
Waycross, GA
Said the man who's not even aware he's NOT talking to OP atm
since he not even read the username :lolgoku:
...pure gold!
Lol. You got me! That's pretty bad I missed that.
It is best to read and use the comments before posting in a thread, but I ended up doing the exact same thing Joe-405 did.
My bad :oops::roflol:
As long as the leverplate's connected to the butterfly you should make use of it.
qtband
St. Louis, MO
Look at this picture. The yellow line represents your cable. The red is the cable sheath. The white circle shows where you need a clamp for the cable. The second picture is the type of clamp you need.
