TT540
Newb
I like the idea of testing the fuel pump to see if it pushes past the carb bowl needle/seat.
I have used such a valve from McMaster car with success as a fuel tank vent "blow off valve" for my Chevelle. I use two in parallel. One in, one out. This way, my tank burps when it's internal pressure if over +1psi or under -1psi (to suck air in).
https://www.mcmaster.com/#7757k42/=1cv7y3s
---------- Post added at 09:45 AM ---------- Previous post was at 09:40 AM ----------
and if you do not use this switch for your handbar, you're a homo:
https://www.amazon.com/dp/B00NZCAA6...pi&pd_rd_r=HC36S49NAMT7RHAJJHM5&pd_rd_w=zRlIw
Actually, it wont work. is only a SPST. but you would be the coolest kid on your block. There is a stripper pole version too.
