Getting surface rust off of tubing easily !
Joe-405
Enjoying New Projects
U.S.A.
Don’t know if you guys knew but if you use drywall sanding sheets (the screen type) it does a super job of taking surface rust off round tubing. A 10 pack is usually about $12 and I get 3 out of each sheet cause I cut them in thirds.
That is what I used to clean up the Desert Karts Panther that was sitting outside a few years or more. It took one afternoon to clean strip and paint. It looks completely different now.
I can try and do a demonstration of before and after in a few days when I’m off again.
I like to use a grinder with a wire wheel, flap disk, or something like 60 or 80 grit sand paper for areas where the grinder cannot get to.
anickode
S.E. Michigan
Another thing that works nicely is plumbing sanding screen for cleaning copper pipe. Comes on a long roll. I really like it because you can tear off a longer strip and get nice long strokes out of it. I use it at work a lot on machine shafts and stuff.
Randy H
I use vinegar to clean my copper pipe. I guess that's for a different forum.
However vinegar is a gnarly rust remover.
anickode
S.E. Michigan
Vinegar is excellent for cleaning it, but roughing up the surface a bit gives the solder a better bond.
Vinegar is also a gnarly corrosive agent, and if not cleaned off promptly will make your rust even worse.
Joe-405
U.S.A.
Same thing.
