Turbo Ranger
karl
North east Ohio
I had no wiring or ignition stuff from the car. So this is what I did.
I bought a dura-spark module from autozone for the 79 car.
I hard wired it to the distributor and used a universal coil and ballast resistor.
karl
North east Ohio
I learned that the carb I have is a Holley 6500 electronic feedback carb and not a plain 5200. It is an early form of fuel injection that uses an 02 sensor, temp sensor, and vacuum data to calculate emissions , and a crude Ecu sends a 10hz signal to a solenoid in the main jet to adjust afr . I think the duty cycle has to change to adjust mixture. I plan on making a simple circuit so I can adjust the afr on the fly in the cab.
karl
North east Ohio
Sounds like a cool idea.
Yeah hopefully it works ok.
The crossover pipe is fabed up from car parts store universal stuff.
Not pretty but functional and 2 1/4 ,factory is 2in.
Need to get a 70in driveshaft made or found.
karl
North east Ohio
Should work ok.
Getting close.
Is converting to a serpentine belt on a future things to do or do you plan on keeping the old school V-belts?
karl
North east Ohio
V belt for now. The dayco belts are not cheap so I’ll run it until I have problems.
I have a y pipe sitting in my yard , freshly painted . And 4.0l hooker headers . Anybody want? Lol
karl
North east Ohio
Wonder how much a custom drive shaft would cost?
About $250 to 400.
Still doing research, I dont want to pay that.
Got the charging system done. And the front clip is back on.
karl
North east Ohio
For now I am using the fuel pump from my Briggs twin kart.
Got the oil , temp, fuel , and voltmeter working. I will use an external tach for now and judge speed from that.
Ready for shaft, I got a slip yoke and flange for the back.
TT540
Newb
Huntsville, AL
An option for speed is to get a MPH app for your phone. I used one for my jeep when i changed tires. Worked well. Has max speed too. :thumbsup:
Too weak of fuel pressure is the demise of many a turbo engine. Be careful there.
For driveshaft have you considered a longer one from a junkyard that you could have a shop cut down and weld a new end onto?
karl
North east Ohio
Yeah I will need the gps app .
I plan to upgrade the pump after the clutch break in.
I found a place that will make it for $270 shipped with u joints, balanced ready to go.
I think that is good for a 70in 3.5in driveshaft.
After I double check the measurements I will order it.
karl
North east Ohio
I ordered the driveshaft , so I need to fabricate a clutch petal, mount the throttle cable, get an air cleaner , and finish the Downpipe before it arrives. And some dumb little things. Then ready for action.
