For a more accurate CC of the Combustion Chamber.....
TN Lab Supply 25 ml Borosilicate Glass Burette w/glass Stopcock
https://www.ebay.com/itm/TN-Lab-Sup...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
Clear Polycarbonate (Lexan), 3/8" x 6" x 6"
https://www.ebay.com/itm/Clear-Poly...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649
Going to drill a hole in the Lexan Plate and seal it to the gasket surface with vasoline or grease.
I don't have a stand for the burette, but I think I can do without one.
2.765" Bore
2.165: Stroke
3.328" Rod
71 Degrees ABDC Intake Valve Closing
0.001" Deck Height
0.027" Gasket Thickness
2.756" Gasket Bore
Chamber Size
SCR
DCR
20.0cc
10.31:1
7.88:1
19.5cc
10.52:1
8.04:1
19.0cc
10.74:1
8.20:1
18.75cc
10.85:1
8.28:1
18.5cc
10.97:1
8.37:1
18.25cc
11.09:1
8.46:1
18.0cc
11.21:1
8.55:1
17.75cc
11.33:1
8.63:1
If I use 72 ABDC instead of 71, the Dynamic CR drops by about 0.1
I think I will be able to safely mill off 0.040"
4 x 0.9338cc = -3.735cc
I will mill 0.035" Minimum or 0.060" Maximum, Depending on the what the actual chamber measures.
2.765" Bore
2.165: Stroke
3.328" Rod
0.001" Deck Height
2.756" Gasket Bore
Chamber Size
SCR
DCR
20.0cc
10.31:1
7.88:1
19.5cc
10.52:1
8.04:1
19.0cc
10.74:1
8.20:1
18.75cc
10.85:1
8.28:1
18.5cc
10.97:1
8.37:1
18.25cc
11.09:1
8.46:1
18.0cc
11.21:1
8.55:1
17.75cc
11.33:1
8.63:1
