cheap speed boost
khariag
i need some cheap or homemade ideas on something i can do to speed my kart up alittle.i have a 6hp tec in a manco 2seat.hits 40mph with a 12t/60t ratio.im switchin to a bigger sprocket,chain and clutch with a 10t/54t ratio witch will probably slow me down alittle.how can i jerk the speed up abit? my money is lowww
khariag
the little screw with a spring on it?.taking that out has no bad side 2 it?.
i hurd if i find a way to get the fumes from the engine cycling thru the engine that would boost it a few mph.sounds stupid to me anybody ever hurd of that?.
whats porting it out
freakboy
the names 'mater
hick town
Ok removing the gov. involves opening up the engine removing the gov. gear and then re doing the throtal set up. Porting it out means you make the intake and the exhaust bigger so it flowes more. you also have to take the engine down sand it down and then smooth it up with scottch britte.
khariag
so its not the little screw with the spring on it?.i cant all of that.i dont know how to put an engine back together
EagleTalons
Master JB Welder
Forsyth, Montana
Not to be a jerk but, if you don't know how to put the engine back together, what makes you think that you need to go faster? If you break something at a higher speed, how are you going to fix it? Like Tyler said, gotta start somewhere.
jr dragster T
Cold place
lol u was an 11 year old junior dragster.
We dont run 3 HP briggs on the Juniors. There all based off the 5 HP STYLE of block. And about not knowing how to take a engine apart. Its like anything else you take apart for the first time. Remove the obvious bolts retaining that object and remove parts and observe how they go back. Realy its just a few sidecover bolts and it looks pretty simple to put back together. Just put things back exactly how they came apart.
khariag
yea i know i just dont wanna mess anything up that i cant fix.if something in the engine breaks im gonna have someone look at it.i got uncles who can teach me my way around an engine.im just trying to stay away from messing with it untill i know what im doing.the most i can do is play with intake and exhaust probly
THE HUNTER
"Ghetto Rigging Expert"
Detroit Metro Area
yeah, like Jr. said. just put it back together they way it came apart lol
taking pics along the way is a good idea!! for governor linkages is a really good idea, they can get kinda complex lol
make sure you watch what bolts go where, some are longer than others, and should be put in the same hole they came out of.
but you should deff avoid the temptation to use hammers to disassemble the engine lol
well, there is a few proper uses for a hammer... but make sure you ask someone with experience before you try lol
other tools to avoid.. hack saws, wire cutters.... cutting torches... that kinda thing! lol
you can always post pics if you have questions, we will help you out :)
khariag
I think he means like a turbocharger? except its more like, you use the exhaust to spin a blower, to create intake pressure, using fresh air, not your exhaust fumes.... Forced Induction
ohh i get it.what parts do i need for that?. i have a blower head.my exhaust is a tank with holes in it do i need to take that off?
modelengineer
Lord of the noise
Sydney, Australia
I think he means a DEI system:
Did anyone else read that topic on another forum, before it got deleted? Funniest thing I've EVER read on a forum.
Kaptain Krunch
Pro Junk Collector
vermont
Sounds promising! Why did i never think of it?! Now i should just attach a hose to my but, with a valve directly to the intake for a super natural gas turbo boost! :roflol:
Khariag, turbo charging aint gonna be easy, for the most part, a small engine doesnt have the exhaust pressure needed for powering any turbo chargers that you can buy, so you would have to make your own custom, then you would have to upgrade you engine's main components so it can handle the extra air/fuel, then you would want to take out the governor to take advantage of the performance boost...its just not worth it, for all that effort you could get yourself a nice sled or MC engine.
khariag
4real.so basically theres nothing i can really do for speed untill i get the guts to take apart my engine?.lol i guess i got some researching to do
