When you are welding a frame, it is a good idea to spot weld before fully welding up a frame. Thankfully this is what i did. because after i welded the first part of the frame to the steering chassis i did it upside down
as you can see in the image and the reference drawing behind it.
So a couple spot welds removed and good to go.
Then i welded up the top part of the steering bracket. It holds but not great. Will need to put set screws in the side maybe? I would weld to steering but i may need to remove later. so i have to do it this way. And no room for a key on the shaft.
And the semi completed internal frame work. Still a ton of welding to do
Sorry looks like i had some bad lighting. I will take some new ones and replace maybe
