High idle
briggs driver
Raleigh, NC
I've been working on a Briggs and Stratton 5hp flathead and it has a problem with a high idle speed. When I push the actual throttle back, it just feels like its floating between my desired idle speed and the current one, but there is a light force pushing it to the current one. does anyone have any ideas to fix this? btw my engine is governed.
KingCobra
TROLL CRUSHER INC.
TROLL TORTURE ROOM
Stronger spring? Idle screw? I guess I'm missing something here. The governor should not bother you unless you hit the red line of RPM's, Maybe bob can pipe in, he loves them Briggs engines....
Do you know what particular Briggs engine you have, better yet, the type of carburetor?
I would assume horizontal shaft, but I won't. Tell us more about it, por favor. ;)
Wow, great help there, Briggs hater, I mean King Cobrah (HIIISSSSS!). :rolleyes: :D
EDIT--you could me suffering from a maladjusted governor. In other words, it wants to maintain your engine at *ITS* desired speed, not yours.
briggs driver
Raleigh, NC
I thought about adding a spring to pull back the throttle but I didn't want to add any pressure against the throttle, lowering top speed.
---------- Post added at 08:46 PM ---------- Previous post was at 08:46 PM ----------
its a model 130202
I'm going to have to also request pics. :p
Too much guessing otherwise.
KingCobra
TROLL CRUSHER INC.
TROLL TORTURE ROOM
I thought about adding a spring to pull back the throttle but I didn't want to add any pressure against the throttle, lowering top speed.its a model 130202
Are your valves seated properly? Check your main jet for debris bouncing around in your float bowl?? How is your carb fed...diaphragm or gravity? Air fuel mixture setting at approx. 1 1/2 turns counter??
I watched that video and did that before. didn't help but thanks.
Yeh, I knew that and that is why I didn't offer you that video :D
What do you expect to 'HEAR' from them pictures??? :D
Randy H
Actual throttle? That's how it works if you actuate the butterfly at the carb with the governor hooked up.
I've never owned, operated, or worked on a Briggs. Predator, Yes. Tecumseh Powersport, Yes. Jiangdong, Yes.
Briggs, No. I have no input on those engines. I stay out of those threads. I have nothing to offer.
We need a pic indeed..
the rear side (where the throttle connect and the governor linkages are)
straight shot, clear, well lit etc...
maybe the springs are messed up.
maybe you skipped the governor entirely (which would be bad)
also we need a model number.
The amount of spring pressure needed to return the throttle to proper idle will NEVER be stronger than the force your foot can apply to the throttle pedal; we're talking a pound or two of pressure...
KingCobra
TROLL CRUSHER INC.
TROLL TORTURE ROOM
Then we need a cool video LOL!!!
I don't believe it! Wow, what country do you live in anyway?
